Well apparently I don't know how to follow simple firing orders because I ended up pulling the wrong damn one, I pulled #4 instead of #2 because of some firing chart I found on google was wrong. I feel pretty dumb lol. Also I found oil on the top portion of the threads next to the silicone connector on top... so I'm thinking piston rings are starting to get worn or the gasket is going bad.My po430 code was excess valve cover oil in intake tract caused same symptoms and cause that cat efficiency code right before my rear cat went out and had to be replaced. Ford wanted 1200 bucks to replace valve cover oil separator, I put on my own.
I have a 2012 that had the same issues. It turned out to be the torque converter. Once replaced no more issues.So I bought a used 2013 SHO with 130k on her, was running fine until now. Runs normal until you start to give it about half throttle to get moving and starts to shudder and then misfires on cylinder #2. I took out the plug in cylinder #2 and it looked fine, almost looks new other than a bit of carbon on the end of it (as to be expected). Did a test on the coil pack and its got voltage so I'm stumped. I don't think it's the transmission because it still does it in manual mode. It seems to quiver at about 2-3k RPM and then misfire when you give it a bit more gas. I've talked to multiple people about it and researched a few forums with the same keywords and most of them say dirty throttle body or nicked crank sensor. Any thoughts?
I was thinking that at first but theres only oil on the top portion of the threads, not on the ceramic part of the plug.Valve cover gasket can definitely leak, #3 has been the favorite location for Gen V. Gen IVs are more prone to leaking on bank 2.
Its definitely not transmission related, thanks for the reply though.I have a 2012 that had the same issues. It turned out to be the torque converter. Once replaced no more issues.
