ATX rear o2 sensor a better way?
First I'd like to thank the SHOforum for this site, the helpful members previous posts, I'd also like to thank my daughter for her support, my Producer and Director...oh wait, wrong forum.
If you bought a hi-miles car, don't assume the previous owner did SQUAT in repairs unless he shows you receipts for repairs.
Previous owner told me he did 60k himself and kept the old plug wires on, which is fine... Decided to check plug wells for oil (after purchase DOH!) yup, they were reading FULL on the dipstick, uhh plug wires.
OK, so better check the plugs, used a gazillion small cut rags on the end of a bent clothes hanger to get most of the oil out, pulled the first plug, (it wasn't even remotely tight!) and it was TRASH! DALGONIT! I was a bigger idiot for trusting him than he was for doing such crappy work.
Decided to replace plugs now, then do 60k VERY VERY soon.
OK, here's the details, if you're going to replace anything in the rear of the motor... plugs, or o2 sensor on an ATX car in my case, it's not difficult to remove the hood and replace it with help from a friend. (stop by your local body shop and ask for pointers)
Pulled the hood off, (5 min) and actually SAW the rear plug wells, cool! Replaced front plugs, all were crap! replaced rear plugs, guess what...Original Motorcraft plugs! The dufus just replaced the front plugs! sheesh.
Anyways, with the hood off they were TOO easy to get to, almost as easy as the front. Decided to replace the rear o2 sensor while I was there, (was getting o2 sensor check engine light) Put a blanket on top of the (cold) motor, and layed...lade...laid...anyways, I spread my big a$$ over the motor so I could look around back there, and lo and behold there it was, that sensor that gets so many people cussin and throwin tools!
I'm gonna try from up here, won't hurt nuttin. (I closed my eyes and used the FORCE, (star wars type) I felt around back there, and tried my 22mm open end wrench and it fit right on there...moved that silver heat shield back out of the way, gave a good heave-** pull on the wrench, and it worked! Got enough revolution I could rotate the open end wrench and unscrew, repeat, till it came out. (Pulled the connector loose from top too...EZ, just look at the new sensor, it'll give you an idea how it disconnects.)
Put the new sensor in place, (again using the FORCE) screwed it in by hand till snug, repeated the wrench crank technique to tighten, snapped the connector on, and we're done. It's really that easy.
To replace the sensor took all of ohh 15 minutes.
If you try it this way, before you remove your hood, mark around the hood hinge bolts (the ones that go in the hood, not the fender support) with a marker to make replacing quicker. Remove hydraulic lifts, and hood light (connector behind the black plastic cover). When you remove the hood, it's best done with at least 2 people, super easy with 3, one holding the side of the hood while you remove the bolts, the other side you can hold while you remove bolts or have a 3rd person hold it. Let them know that it's a balancing act, don't let it fall into the windshield, don't let it tilt forward. It's not difficult, but if you've never removed a hood before, ask for help so you don't scratch your paint job. (Remove the upper hood hinge bolt first, then the lower bolt).
Replacing the hood is pretty much the opposite, align your bolts with the marks you made before you removed it, snug bolts up, not loose, not totally tight, reinstall hydraulic lift cylinders and hood light, slowly lower the hood, (don't let it latch, you're checking hood to fender and bumper cover gaps at this point) If gaps are good, raise hood, tighten bolts, SLOWLY lower hood, double check gaps, if all is good, close the hood. Make sure it releases to open, if it does you're done!
Hood remove and replace, 15 minutes
Plug change, 1 hr (@#$% oild in wells!)
o2 sensor 15 minutes
When I do the overhead (upper 60k) that hood is gonna be off the car leaned up against the wall (with rags under the corners of the hood between it and the floor)
Anyone tries it, let us know how it works out, (BTW long skinny arms replacing o2 sensor is a BIG plus).
MAY THE FORCE BE WITH YOU! and with all things, look and think before you jump in with tools. A SHO is a terrible thing to waste.
