Normal temp gauge reading
opalmtx
douglasville,ga
I have a 94. The temp gauge usually stays between the o and r during city driving. If I stop at a light the fan always kicks on. Is this what everyone else's reads? If not what does your read during city driving?
yamahaSHO
E85 whore
Arkansas
This is an EXTREMELY rehashed subject.
Please take a look around on this forum.
Mine does not get much over the "M"... But I also have my fan turn on at 208 degrees versus stock's 216.
opalmtx
douglasville,ga
Thanks for reply. I searched before I posted. My 94 is the only car I've ever had where the fan cuts on so often, even after three thermostats.
n8rsk8r
Hey Where's my post?
Olathe, Kansas
hey
get some watter wetter from Redline Performance (maker of it) it will do some good for you!
nathan
SuperHO
Mental Patient
St. Joe, MI
HAH! since the removal of the A/C condensor on my 92, my temp guage almost never makes it to the M....in fact, it usally sits right above the bottom line while in motion.
yamahaSHO
E85 whore
Arkansas
Your fan is kicking on so often because it is trying to cool the car. Stock, the fan cuts on at 216 degrees and it cuts off at 192. A lot of times it could just be the guage. If you are into replacing things... Don't try 3 different t-stats(test them), try replacing the two coolant sensors.
EDIT: Best bet is to wire up an accurate gauge where the stock gauge sender is. This way you'll know what you are running.
yamahaSHO
E85 whore
Arkansas
Hook it up to a switch and give it power when you want, or your best bet is to get an LPM, TwEECer, or SC Tuner.
