No start situation after plug well seal replacement, intake cleaning, etc...
93redATX
SHOForum O.G.
WI
I just got finished replacing the plug well seals, valve cover gaskets, intake gaskets, new plugs, and new wires. I finally got done putting everything together, and it doesn't start. It will turn over, and the tach goes to approx. 500 RPM but still no go. The battery is fine. The EGR valve gasket was not replaced, but looked pretty ******. Did not apply any dielectric grease to the DIS because we did not have any. Also, some of the original bolts holding the intake on were replaced with ones from a hardware store (these were metric and the right size). I do not see or understand where my problem lies, so any help will be greatly appreciated.
-Andy
'93 Red/Black ATX
-Coneless
-Red interior lights
-Fog light mod
-Pioneer DEH-1100 45x4 MOSFET Head Unit
-SHO lettering painted black
-SHO banner on windshield, SHOforum.com sticker on back window, bottom center
-Gen IV Taurus emblem on trunk
My Website: http://taurusshosite.8m.com/main.html
AIM:Juggalo53048
AutoXSHO
Glenwood, MD USA
I bet you forgot to plug something back in. Both DIS connectors, and the coil pack plugged in? See if she throws a code.
Either that, or the plug wires are on incorrectly.
John V
fredhurderjr
www.neshospecialists.com
Possibly flooded? Did you use a lot of intake cleaner in the lower runners (on the heads?) MASH the gas & hold it there while cranking - see if it fires.
It's probably a disconnect or missing ground or something, but just a thought.
93redATX
SHOForum O.G.
WI
Well, I moved the wires according to what was in the Chilton manual and there still is no spark. There also is no gas going to where it should be going. Does anyone know the firing order for the plugs and coil pack?
If the wiring were incorrect on the coil pack you would still get some plugs firing. They may be backfiring, but you would still get some response. The correct order on the coil pack is shown below.
Firewall
5-1
6-2
4-3
Radiator
I bet your no-start condition has to do with the lack of ground to the DIS module. You mentioned not using dielectric grease when you reinstalled the DIS. Good thing. You need to use Heat Sink Compound available from Radio Shack (small tube near the soldering supplies). Did you reconnect the ground strap to the passenger side rear intake manifold support bracket? Did you install and tighten the two bolts that attach the crossover tube to the plenums? The ground strap and the mounting bolts provide the ground path for the DIS.
Another possibility is the electrical connector to the coil pack. Is it securely attached? How about the two electrical connectors to the CPS that are located just inside (the valley) from the rear timing belt cover at the passenger side of the intake manifold. Damage or remove either of these and you will guarantee a no-start.
Scott
[This message has been edited by sdpatt (edited 12-06-2001).]
poissonverte
iowa city, ia
WINNER #2!!! The chiltons is WRONG.. I found out the hard way also.. search around the posts im sure the firing order is posted somewhere.
Diameg
Ontario, Canada
Isn't it incredible that it's wrong in Chiltons!
Like, thanks a lot guys! Any other bad advice you want to give me for my car?
Hey, new business idea for me. I'm going to publish and produce a manual dedicated to the Ford Taurus SHO. Sure...I don't know anything about the intricacies of the car, but apparently that is not a prerequisite.
94 MTX (Rare Green model)
Hi Flow Y-Pipe, Dynomax, UDP's.
93redATX
SHOForum O.G.
WI
I corrected the wires, but it still wouldn't start. I tried to start it two more times and then on the third try nothing happened. All that the car did was make this weird click noise. I was looking around on shotimes and I found an article about the starter/starter relay and how if that goes it makes a weird clicking noise. Is it possible that the starter/starter relay went out?
[This message has been edited by 93redATX (edited 12-06-2001).]
S
slosho
Guest
Your battery is probably just dead from the repeated cranking of the starter.
95' ATX Silver Frost
Cone Filter W/ heat shield
TB coolant Bypass
Bypassed a few "PCV" line
Lighting mods
Sony head unit (el cheapo cdx-650)
JL Monoblock 500
JL 2-12w3's
Rear tint
More to come.
93redATX
SHOForum O.G.
WI
Update on no start-
After looking everything over, it appears the engine is not getting fuel. While checking spark, no fuel smell came from the cylinder, and the way it is turning over but not starting is consistent with no fuel. Is there anything that could have been bumped or anything like that?
Check the basics. Turn the ignition key to ON and listen for the 2 second long, steady pitched whine of the fuel pump. If not, have you bumped the impact shut-off located on the driver side of the trunk? Press the reset button. Have you reconnected the gray, 1/4" vacuum line from the fuel rail pressure damper to the front plenum?
Are you SURE that you are getting spark? Before you had said that you weren't seeing any spark.
Scott
jedhead
westminster,ca
Hook up a timing light to check to see if you have spark. Pull a plug as smell for gas. You are missing fuel or spark.
Bob
bigdoggee
foxboro, ma
Try this!! Replace those hardware store bolts with the orginals and see if the car starts then. I know that the DIS is grounded to the intake and will not allow the car to start if not grounded properly!! The car will turnover, but not start!!
HELLBENT93
Phoenix, Az USA
You guys think the firing order being wrong in chiltons is funny? you should see when they say to check the supercharger fluid haha
good ol chiltons
poissonverte
iowa city, ia
chiltons has given it to me mor than once up the .... oh well.. let us know what you do and what happens.. did you connect the battery?
white94sho
Berea, OH
3.8L TBird SC motor was the original plan for the SHO. Hey you think the SHO is hard to service try working on that F***ing motor.
