silversho89
Whatever
Well ive been having this no start issue for the past couple of months. (Since May 6 actually) Ive come here for help before but with no success obviously. So im coming again hoping that since i have it more narrowed down because of the amount or parts ive replaced, i will be successful this time.
Anyways, the Crank Sensor has been replaced and the tach does move when it cranks. The cam sensor and timing belt were also replaced at this time. ECT and TPS have been replaced. DIS checks out perfectly too.
The reason i replaced the TPS was because i finally found my code reader and tested the car. TPS voltage came back low. Well after no luck with that, i pulled the voltmeter out like i should have before and im getting no voltage to my tps what so ever.
Mike Kopstain suggested that I check around for bad grounds but everyone 1 found seemed good and i cleaned them anyways for the **** of it.
Anyone had a similar problem or just yet a similar problem? It would be much appreciated for any opinions to help me solve this menace. Its probably something stupid and simple but im too frustrated with it to think clearly and straight.
TIA,
Roberto
TIA,
Roberto
