Green Sho
So about a month ago I parked the sho(93 mtx) due to a broken rear passengers side subframe cup. I've have been waiting for a few reasons till this week to get a new subframe and put her back on the road.
I went out to start it for the first time in 3 weeks since I parked it it just cranks and will not fire. The fuel pump is coming on I believe I'm getting fuel but I checked and it has no spark.
The car ran fine before this I had a stall issue last year but it was due to the connectors being cracked on the DIS and falling off. The connectors are definately connected now. I have a 93 atx with a seized motor that I grabbed the dis module and the coil pack and switched them out one by one with the same results. I also grabbed the body control module ( next to the fan in the front) and switched it out with the same result.
I did plenty of searching and checked all my grounds and connectors and everything seems to be ok. I did notice when cranking the check engine light is on, but it flickers when cranking. Previous to it sitting for a month for a broken subframe, it did not have any no start or stalling issues.
I'm stumped....would a crank position sensor fail after sitting for a month?
