No Power to Overhead Console Map Lights and Moonroof
peglegtom
Waukesha, WI
I have no power to the front overhead console on my 99. The map lights and moonroof don't work. Don't see any fuse listed for this in the manual. Any ideas?
Thanks
centrallaw
Tampa
Fuse is Marked ACC me thinks
Fuse is under the dash and is marked Acc.
It is a 5 amp me thinks.
peglegtom
Waukesha, WI
Thanks, I check it out this weekend!
I' in China right now on business, but will be back this weekend and will check the ACC fuse.
peglegtom
Waukesha, WI
Problem Solved
After checking every fuse since there is no ACC fuse (at least on a 99), and finding none blown, I pulled down the overhead console. The wiring harness was not connected to the switches:confused: Plugged it back in, and everything is now working OK.
Thanks for you input.
That may be after frustration of the door ajar switches prone to failure and keeping the interior lights on. Keep your eyes open for that. You'll see the red open door light on the dash too.
