SilverSHO
I fixed the oil leak! A new oil pressure sender solved the problem. I'm still getting down and looking under the car every time I park.
It's still got other issues that I can't figure out, though.
I have a problem with constant backfiring through the exhaust. I don't know where it came from, but my dad suggested that some of the valves may be burnt. A check of the cylinder balance revealed that cylinders 1 and 3 are weak.
According to my dad, if the exhaust valves in those cylinders are indeed burnt, the valves would not seal properly, and some of the exhaust gas would seep out and somehow cause the incessant backfiring.
In other news...other codes indicated that the rear O2 sensor indicates rear bank lean; PIP failure; and SPOUT circuit open. I know about the PIP and SPOUT codes, but how could the car be running lean when the exhaust is slightly smoky (grayish in color, LOTS of smoke when I rev the car at a standstill) and smells strongly of unburned gas all the time (cold and warm)? I had figured that it would be running really rich, especially with the bad gas mileage. I'm baffled.
Nick
Lt. Titanium 90 135k
Coneless, ACCEL 8.8 stainless steel wires,
SHO Shop torque limiters, Cherry Bomb Turbo II mufflers
AIM: loudog6491,
TitaniumSHO
Nick
AIM: loudog6491,
