I am assuming you have a climate control head.
If not the checks for power are similar. You can access the connectors by dropping the glove box down.
The blower motor has it's own fuse, a 30 amp one. Is it ok? Also check for voltage between the two heavy wires in the blower motor controller connector and ground. The black wire is ground and the other is the return from the motor. If you have 12 volts from black to ground, you have an open circuit in the harness. If you have 12 volts to ground on the other wire you have a problem with the speed controller.
The other two smaller wires are 12v to the controller and the control signal from the head unit.
Does the fan work if you move the switch to max?
If there is no voltage on either wire, find the motor connector, a two wire connector with a partially rounded side. this should be up near the top left side of the blower part of the housing. Check for 12v on one of the wires. This connector gets power from the fuse panel when the ignition is switched on.
Hope this helps,
Bob
