No Fuel?
gbizzle27
Bradford, Pa
We just changed the fuel pump, guessing that was the issue for our no start/no fuel issue. However, that seemed to be a false diagnosis. So what other parts could cause no fuel? Its a 97.
Bad inertia switch in the trunk. Bad relay in the CCRM. Bad crank sensor. Bad wiring.
I would try to hot wire the fuel pump at the inertia switch under the trunk lining on the passenger side. This would confirm the pump and wiring to it from the switch.
gbizzle27
Bradford, Pa
Right after I posted here I remembered. I played with the inertia switch to make sure that wasn't the problem before, and maybe I left it poped up. I did, so now she is running like a champ.
