ricky
past three mornings SHO hasn't wanted to idle after first start of day. will start then die, start then die. will stay started if I feather the throttle slightly [900 to 1000RPM]. a couple of minutes warmup and it's good to go for the rest of the day. no codes. fuel pressure is good. checked at end of day. probably should check in the AM but 4AM
