No cluster lights
SideSHO09
Ca
the light where the speedo and tach are hasnt worked since i got this car. Fuse is good so im guessing the bulb is burnt out. Kinda sucks not knowing how fast you're going when driving at night!
From what i've been reading the dash needs to be removed to get to this light.
Is removing the whole dash something i have to look forward to or is there an easier way?
Vnuk1
Mr. Mayhem
Minnesota
Are you sure its not just the dash dimmer switch needing to be replaced?
SideSHO09
Ca
you know what, that could be the problem, never thought about that. so how do i go about replacing it?
Kens1992mtxSHO
The Commonwealth
FWIW, I've replaced mine with a JY unit and it's worked fine for about a year now. Might be worth checking one out if there's a JY near you.
SideSHO09
Ca
Theres no jy around here so i might have to order it online. The local autozone has it but for $50
