No 4th gear on ATX... here's how to fix the c-clip
Huntervf
Bored now
Back in Michigan ... again.
Since I thought my trans was toast and then found it was just a c clip, the least I could do was share the procedure with the rest of the community! I do have this submitted at SHOtimes.com, but since they have over 200 submissions pending I'm thinking we won't see it anytime soon, so here's the complete how-to (with pics) on this relatively simple procedure :cool:
If you've lost just 4th gear but the trans still works reasonably well in the other three, you may have simply broken a c-clip on the 4th gear servo. The good news is that a replacement clip for about a buck is all you need for parts. The bad news (and it's not even that bad) is that it can be a little difficult to replace with the trans in the car. Now that I've done it, I could make the repair in less than an hour, possibly quicker if I had a nice set of ratchet wrenches.
Before I get into the procedure, I want to point out that I did have some slippage in overdrive just prior to this happening, and once I lost 4th the computer did set a code (638 I believe, 4th gear failure) and I had slightly erratic shifting in the other 3 gears. Given those symptoms I was convinced something major had happened internal, but they all appear to be related to just that c-clip breaking. Perhaps the computer remaps the trans operation in the event of O/D failure, I don't know. But I do know I'm very glad I checked for the broken C-clip, and with it replaced the trans is shifting a-ok through ALL gears once again.
Now, on to the procedure:
This is the servo shaft and cover; it's little more than a metal shaft with a big spring over the whole thing, a small spring held by the infamous c-clip, and a flat piston that rests in the servo cover.
This is where you'll find the servo. Sorry for the blurry pic; it's hard to get good shot in the fender. The camera is sitting where the driver wheel would normally be, looking towards the passenger side. You'll notice the tie rod in the right side of the pic; it's quite crowded in ther with limited space, hence the ratchet wrenches or a 1/4 drive socket wrench. This pic shows the cover and servo already removed; simply remove the driver wheel to gain access. The cover is right on the trans and faces directly towards the firewall and steering rack. In fact, there's barely enough room between the trans and the steering rack to get the servo out. The cover is held in by three 8mm bolts; I used a 1/4 inch socket wrench for the bottom two and a standard 8mm wrench for the top buggar (too tight to get the socket in there, and I didn't feel like going out to get a ratchet wrench set.)
Once the bolts are out, you'll likely have to either gently pry the seam of the cover with a flat head screwdriver or twist back and forth with your hand. It is spring loaded, so once it comes loose it'll pop right out. The cover will hit the steering rack; I found it easier to remove the cover from the servo first, then remove the servo assembly.
Again, sorry for the blurry pic... guess my camera sucks! This is the complete servo assembly, the cover is on the right, with the shaft, piston and smaller spring in the middle. The large spring on the left goes over the whole shaft and just rests against the servo cover.
The culprit itself. There are actually two of these thumbnail-sized clips holding the small spring in place on the shaft, one in back:
and one in front:
I found the front clip to be broken on my 93 ATX, so as soon as I had the cover off I saw the smaller black spring loose on the shaft. After I removed the servo I found the broken clip laying in the trans. When installing the new clip, make sure the you have the small shield on the black spring facing AWAY from the piston, as pictured above.
Now, the hardest part of the job for me was reinserting the servo into the trans. I found it easier to have the whole thing assembled (servo shaft into the cover) for installation. Spread a little bit of Vaseline around the edge of the servo cover to help it all slide back into place. Make sure the pointed end of the servo shaft is inserted into the slot in the trans... I had to go by feel since it was impossible for me to see but you'll easily know when it's properly slotted in. When you're confident the shaft is in the right spot, push the assembly back onto the trans. You'll need some arm strength, because not only does the cover make a tight seal against the trans, but you'll have that big honking spring pushing back as well. Here's where the vaseline will help, as you'll be able to slide the cover on far enough to get your 8mm bolts started. I personally didn't push the cover all the way on, I got my bolts started and then torqued them down in sequence, giving each one a few turns at a time to ensure the cover was going back on straight. Once they're tight, put the driver wheel back on and go enjoy having a fully functioning transmission again!
hawkeye18
Sorta cares
Norfolk, VA
And I bet a lot more people will care about this write-up than my window motor write-up! lol
I for one have saved this thread for when, not if, one of my two ATXs does the same damn thing.
1993MTXSHO
Its a Taurus...
Jersey
Hasn't this been on shotimes for years and years already? or do you mean you submitted the whole writeup to them?
Huntervf
Bored now
The c clip fix has been there, but it was little more than just saying to replace it. No real mention of how it all goes together, or how to get the servo back in the trans. When I first took the cover off, the freakin' thing shot out because it's spring loaded, I didn't know exactly how the assembly was supposed to go together since it came out broken, and it was a real PITA to put it all back in the trans. Also, I couldn't find mention of other symptoms resulting from this broken clip, which I honestly thought was something internal. Hopefully my knowledge gained on this can help someone else save some dough and identify an easy-fix problem even if they think it's something major.
TimboSHO
Intermediate
Wyoming, MI
Glad to see you got it all together Chris. Isn't it great when it's something simple?
1993MTXSHO
Its a Taurus...
Jersey
ok cool, yeah great writeup, the little paragraph on shotimes doesn't do anything it just lets people know its a problem, no help on how to fix it though, I hope they post your writeup it would probably save a few shos from the crusher:thumb:.
Mr Anonymous
Tire Wall
Chris' post was already posted and stickied in the "How do I..." section of the forum back on Monday night. Try to pay more attention. :shakehead
Phoenix
SHOHOLIC
QC , Canada
Got ya , It probably slipped through when I go through 'newposts' :thankyou:
