Newbie needs help
iumba2003
Pelham, AL
Well, actually this is my second sho...first one was a 1992 that I sold years ago. I now have a 1995 MTX.
I am sure my problem is a familar one, but I have done some research and am still having trouble.
Background...
I was driving down the highway at around 55mph when the car just died.
I had a friend of mine turn the ignition while I check a plug wire for spark. I had spark. The fuel pump was priming. Just figured it was a sensor. The car would occasionally start and occasionally not. I believe the problem to be the crank position sensor (as I thought that controlled the fuel pulse of the injectors, but I am now thinking I may be wrong).
anyway, I replace the crank position sensor. I was sure to set the gap between it and the vanes on the crank to 0.8mm.
Now when I go to start the car, I still get spark (at least to the plug I was checking) and I can smell fuel.
I never touched the timing belt, so I know it cannot be "mechanically" out of time, but I am now wondering if it may be the DIS?
Also, I noticed that all three of the front bank plug wires were coated in oil indicating that I have an (apparently common) valve cover leak. But I don;t think that this is the problem with the car not starting.
I'd really appreciate some advice from the seasoned veterans of the forum.
I know this question must have come up a million times before, but I honestly searched and couldn't find the info I needed.
Many thanks in advance,
Mike Wiehl
iumba2003
Pelham, AL
Just to clarify...the car WAS working intermitantly. Now it won't start (or even catch on one or two cyclinders) at all.
sho_me92
it`s SHO time
utah
it might be your MAF clean the connecter and run the codes and we will see were your at
