new wheels and tires
nnobody825
'15 sho non-pp
It will buy.
Wheels: Thailand Manufacturing / Low Pressure Cast / 27.0 lbs (low weight and cheap)
Tires: pp tire (eagle f1 supercar)
How about the quality of the thailand tires?
If the product is good, please recommend a lightweight wheels and tires. :)
index.php
r1crusher
Ohio
I personally think there are much better tire options instead of GY tires. What are you driving habits? What area of the country do you live in? Those tires are summer only tires and will not do well with any snow and ice. The tread rating of 220 also means they will last half as long compared to other tires available.
Again, IMO...find a different set of tires appropriate for your area and driving.
SHOnUup4
SE MI
I'm using Hankook Ventus V12 Evo 2's...not as expensive as most and have performed pretty well. 1.754 60'
It is a summer tire though.
nnobody825
I'm going to buy a summer tire.
I want a lightweight wheels and max performance lightweight tires.
nnobody825
cheap and lightweight good!
What are your wheels?:)
Weight isn't everything, so don't go TOO low. Unless you like wheel hop & that sort of thing. A few pounds is OK. The lower the sidewall, the less of a streetable tire it will be (in general), it is basically shifting the work to your suspension.
PokerMunkee
I ♥ AWD
Denver, CO
You don't need that $45 tire reset tool. Tire rack told me I needed it for my winter wheels, nktnot true. The car can learn two sets.
r1crusher
Ohio
Gotcha. I would still be looking for something with a better wear rating, IMO.
Good luck with your search!
PonySHO
FOG
Joe's Garage
I had the F1s replaced before I took delivery of my '15 with PP. I put on BFG g-Force COMP-2s. I didn't want to have to worry about how the tires would handle cool/wet weather in the Fall. I also have a set of Blizzaks I put on for the winter. I'm concerned though about the TPMS. I've got the band type sensor on the Blizzak wheels which is what the '10 used. The '15 uses a valve stem mounted sensor.
Aeterna
Austin
Im running Goodyear Eagle RS-a2 they have great tread rating and are an all season tire that performs really well for the money.
Havent used them in snow, but i have used them in intense rain and muddy roads they perform great although for more money there are better tires out there.
