new spark plgs broken valve cover bolt
Black-taurus
Minneapolis, MN
I am going to get around to changing the plugs finally after last weeks disaster of breaking a valve cover bolt. The valve cover bolt is still stuck in the head. I was told to use an easyout to remove it. do I want to get the smallest one or the largest one possible? Do i want the head to be warm hot cold what which will help the ******* come out? what should I torque the rest of the valve cover bolts to considering this one broke at around 12 should I go down to 8 and be safe. will that be a problem? also I have another dumb question. I've never done a tune up before but what is the ring that comes with the spark plugs for. do I put that on the thread of the spark plug (like a gasket. and how far down do I torque the spark plug? in other words is there a torque spec or do you tighten it till it can't be tightened?
thanks again
91 Plus
Well-Known Member
Monroe,Michigan
We broke a valve cover bolt on a buddies sho. We took a small screw driver and kinda tapped it in to the rest of the bolt.With enough pressure we were able to turn the bolt free.Good luck.
AREA 91
PA SHO SHOP
Area 91
I torque mine to 7 ft lbs, no more!
If you want to try, you can heat the area around where the bolt is threated into the head. Not the bolt itself.
If you have the room, I sugguest that you cut a slot into the end of the bolt. Then use a screwdriver to back it out.
Let us know your progress! :thumb:
rangerj
Brunswick, Ohio
Torque spec Spark plugs - SHO 17 to 19 foot lbs
Cylinder head cover to cylinder head 8 to 11 ft. lbs torque.
Sears Hardware sells a broken bolt extracter set for about $25. It includes reverse drill bits and the attached extractor. The extractor can be set to depth, and will engage the broken bolt when you drill deep enough. The reverse action of the drill will turn out the broken piece. It works very well. rangerj
fastsho92
SHO POWER!!!
Exton P.A.
i broke a vavle cover bolt on my sho but i didn't do anything about it. i just left in sitting there and nothing ever leaked out. TO MY SUPRISE. but i just left it there and never had a problem with it. i should really take it out tho. but i thought hey why spend the time to take it out if it is not causing me any probablems. so if you start up the car does it leak at all anywhere. if not y change it out. :D
Black-taurus
Minneapolis, MN
thats how I'm driving it right now. I guess I would just feel better if I had that bolt. did you seal it with the old bolt and som high tack or black ****.
also What are those rings that come with the spark plugs for Am I supposed to use them?? :confused:
40BelowSummer
Puerto Rico
yeah, install them with them on. they are just to ensure a seal. Make sure to use some anti-seize too.
