New Oxygen Sensors...New code (136)
SHOByrds
Virginia
First i had the code 172 ((R,M) Oxygen sensor not switching - system is or was lean - Single, Right orr Rear HO2S - Fuel control.)......
I put new O2 sensors in, and 172 still came up along with the code 136 (R) Oxygen sensor not switching/system lean Left or Front HO2S - Fuel control
Any help would be appriciated
(i reset the codes by unplugging battery before running test again)
that means you are getting more air than the pcm is being told. this can be due to a significant vacuum leak, or a bad or dirty mafs.
I would check carefully for vacuum leaks - they can be hard to find because old, hard vacuum hoses can leak a lot. And, I would clean the mafs. Then, reset codes again and drive another couple days to see what pops up.
shobroooo
