New dash and new carpet **with pics**
TaurusGuy
Omaha, Nebraska
BTW, about that equalizer, how does it wire up? I got mine today, and it has this with it:
The EQ
One Plug with two ends the same (Six pins, in two rows of three)
One plug (Six pins, one end plugs in, the other has 5 bare wires)
One Plug that apparently attaches to the metal frame on the back
One is labeled Radio Signal In on that pinout, where does all this shit wire in at?
<small>[ June 24, 2003, 04:20 PM: Message edited by: TaurusGuy ]</small>
jelloslug
Digital
Greenville, SC
Its not needed, but the install is different with a slave CD player.
1) Pull out the JBL tapedeck, look on back and remove the jumper plug thats in the 6 pin jack (If there is no jumper plug you will have to do internal modifications, I can help you on this)
2)Plug the 6 pin cable into the Tape deck and into the EQ.
3)Using you wiring diagrams, splice the other cable into the radios power wires. then plug this cable into the EQ.
4)Everything should work now.
DJ SHO
NY
Mitchell, get the list i sent you?
It's too late tonight to do anything. First thing tomorrow, it's DIGIDASH TIME! :cool:
DJ SHO
NY
Taurus guy, could you post two more pics for me please? I'm looking for electrical diagrams for the power moonroof, and the power windows.
Thanks, if you got time.
TaurusGuy
Omaha, Nebraska
TaurusGuy
Omaha, Nebraska
OK, I can put the connector in no problem, and splice everything but one thing. Radio ON Signal. Where does that come from? Thanks again!
jelloslug
Digital
Greenville, SC
Its pin 7 (Orange/LT Blue) on the radio power connector. I have seen some cars where the pin is missing, if so just make your own out of a spare connector or get a terminal for Radio Shack that will fit the pin.
