New 2012 SHO owner
bigeddy6
Bala Cynwyd
I recently bought a 2012 Ford Sho. It was sitting for a while. The owner did not want to put any more money into it after replacing the water pump. He still owed money on the car.
I'd like help getting best performance out of the vehicle. What websites to use to find parts.
So far I replaced both turbos and did a tune up. Replaced front and rear suspension, shocks and struts. Put a rust protective coating on the bottom.
Going to repair leak in bottom rear of engine. Other then that the car runs great. I need to replace the driver side headlight. Thinking of treating the coolant and transmission fluid.
Any info would be appreciated
Thanks
Always change the fluids if you don't know the condition. The lifetime fluid in the PTU is not lifetime and needs to be changed. There are many posts and threads on this.
kryptto
South East, Florida
@bigeddy6 check peoples signatures and start digging thru the Gen 4 threads... this is the only place to go for anything SHO and advice. don't discount older threads not much changes on this platform other than a shrinking parts well.
lingyuair
