Need VSS part numbers
Mike Kopstain
Arlington Heights, IL
I need some VSS help. I have a 97' SHO tranny in my 95. It's an AX4N. Here is the problem. I keep getting the wrong part. I ask for the 97' SHO AX4N VSS and it's not the right size. In fact I asked for the 95 AX4N VSS also and it's the same part as the 97' one. Anyone have any problems getting the wrong part??? This is driving me nuts. If anyone has ANY part numbers or ANY pictures it would really help me out, as most stores have to order this and they keep ordering the wrong one. :( Thanks!
LaTechSHO
Louisiana
it should be a S8058 Borg/Warner part number... as far as other brands....i don't know try to crossreference it
Louis
SHOfun 93
Euless, Tx (Fort Worth)
Dang, Torrie sent me the DY-587 Motorcraft one. That doesn't have "teeth" on it to grip the internals of the tranny to get a signal to the speedo. The VSS I got installed the last time didn't work. cuss The VSS Motorcraft part # for the part I have is E9TZ-9E731-A, and it isn't the right one for my AXOD tranny. Can anyone be of help here? headbang
<small>[ May 26, 2003, 03:18 PM: Message edited by: Jeremy Hohn ]</small>
SHOfun 93
Aren't I the *******. It took my g/f that thinks I need to change her blinker fluid to suggest that I remove the old teeth off of the old VSS and put it on the new one. Problem solved due to the next SHO princess!! RIIIIIGHT! doh
