Need TPS set up proceedure
Mike Spataro
E.Meadow, NY
My 93 ATX is acting up. CE light is comming on and found error code 124. Throttle Position Sensor may be bad. It was replaced 2 years ago and I remember reading a setup proceedure from SDPATT. Can you help??
philw349
PhilW
Tucson, AZ
I'm not sure what a setup procedure is but I replaced mine not to long ago. Just two screws, and it comes off. You can drive your car to autozone, take it off, have them test it, and put it back in inside of 10 minutes. And buy one if you need it of course. Sometimes the screws will seize up so vice grips might be needed in some cases.
