Need To Replace Valve Cover Gaskets
NEILL93SHO
Yuma Az
My 94 MTX has the oil leaks into a few of the spark plug wells. So far it has not hindered my car. I am off this week and want to fix the leaks and take care of anything else on the top end that i can. I have had the Itake off my last SHO and want to do this myself, however , i am looing for some hints from those that have done the valve lash adj etc before. I plan on taking a trip to the SHOSHOP (45min away) tommorrow to get the tools needed. If there is anything anyone can share, threads, pic, I would be appreciative. Thanks
Blue-By-U
CT
There is a ton of info right here on the forum. You can use the search feature to access past threads regarding spark plug, plug wire, valve cover gasket and plug well seal removal/installation. If you never performed a full 60k before, I recommend purchasing the 60k video from www.shonutperformance.com ; it serves as a great visual reference. Good luck!
