Need some turn signal help here!!!
ShoGuy93
Yes I Have Blue Rims
New Palestine, Indiana
Ok for the past couple weeks or so i have been noticeing sometimes when i go to turn, and i have my turn signal on there is no arrow flashing. But i can here it clicking in there like a normal turn signal does. I mean sometimes the arrow lights up sometimes it doesn't. Well for the past week i haven't been driving the sho because of the snow here. So tonight i went to the gas station to get gas and when i turned on my signal it didn't come on. So when i came home i looked at it. And my arrow doesn't come on in the inside of the car. And on the outside the front lights they just come on and stay on till u either turn or turn the signal off. And they don't flash. (didn't check the rear) So would this be the hazard/turn signal flasher? And how much does one of these units cost??
Thanks a bunch
LaTechSHO
Louisiana
ok, i can't resist..... change out your turn signal fluid with the redline synthetic type....
and.... as steve said.... it could either of the three... but my money is on the flasher... and its like a dollar or two at any parts store or walmart...
Duff
Box Elder, SD
If the problem happens with both the left and right turn signals, the problem most likely lies in the flasher. If it happens with one or the other, it is most likely the MFS. You may be able to get the turn signals to work by moving the turn signal stalk around.
Regardless of whether the turn signal is flashing or not, the indicator in the dash and the front and rear turn signals should all light together. If you are getting anything other than all three on or off, I'd start checking bulbs.
