Need some help, suggestions
SeanMc
NoMoSHO
Coming home from a car show on Saturday, my car started stumbling about a mile from home. I check the codes, and got one for both the cam sensor, and DPFE. Changed those Sunday morning, no more codes. The car is still stumbling. I opened the hood Sunday night, and see that there is some arcing from 2 of the plug wires to the head and intake. Plug wires are in the mail. This morning I move it from the street to the driveway (street sweeping day), and smell gas pretty strongly. I open the hood while running, and while I do see the little arcing, just for giggles, I unplug the MAF. CEL comes on, but there is no change in running condition. If the MAF is unplugged, shouldn't the idle change? Also when revved, there is a random "POP" that sounds like it's coming out of the intake.
Anyway, thanks in advance for any help/suggestions.
bertha66
central oregon
If as you say you have arcing around the plug wires, I would put on new wires. Untill you get the arcing fixed, I don't think that the idle will change much with the MAF unpluged.
SeanMc
NoMoSHO
It is a wire. I swapped out the MAF with a known good one, and it did the same. I looked around online and they said if you could hear the RPM through the radio, it's your wires. Went around the block, and sure enough!
shoclown
shoclown
sacramento ca
are the oil wells filled or is it simply a bad wire?? when i had a bad plug wire it sounded like you are discribing....
