Need some advice please
csmith
NC
2015 pp. blow off valve/ boost control problems
76FoMoCo
Nampa, ID
is the boost line hooked to the solenoid for the BOV? you could be a little more descriptive this might get you more help btw
csmith
NC
Ortiz tuned. Had an airaid but switched back to stock with k&n drop in recently. Somehow the aftermarket intake hose popped off a few days ago and I put it back. Bov’s are vta (stock). The problem is that now, when I’m half wot and into boost, the bov’s start spitting air at 3k rpm’s. I can mash the gas more and push past that but I don’t know what the issue is yet.
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
Shoot us a datalog and we'll check it out. Can be multiple reasons, also would recommend posting pics of the engine bay so we can look to see if anything looks off.
csmith
NC
I found the problem….looks like a small vac hose on the charge pipe popped off. Problem averted. Thanks to all though.
Cfields
Minnesota
Do you recall where the hose was? Sounds like the same problem I am having right now
FiveLeeter918
Tulsa, OK
Look on the charge pipe crossing over the engine, there is a ****** and 3/16" hose coming off the charge pipe pointing toward the passenger wheel well. I guess Ford never anticipated us raising boost because they left the boost reference line unclamped, and with elevated boost it blows off. Most use a zip tip and yank down on it to get it to stay on without sticking out too much.
Without this attached the car will think you've got no boost and will send ALL the boost. Typical to see 20+ psi while also having very low WGDC.
Cfields
Minnesota
Thanks! That was my issue!! Put it back on with zip tie and no more problems! Now on to adding more fun parts!
shootinirons
