Chaz1123
Hello there!
I came across this forum a month ago, and it has helped me out on a few things already, so I just registered the other day! But now I have a new problem I'd like a little help with...
I have a 95 MTX w/ 153k miles.
The car's idle is rough (drops under 500RPM, then kicks back up and repeats) After this it will stall, or I'll give some throttle and that seems to keep it steady. Whenever I take it out of gear (red light, etc.), I have to stay on the gas. On incline I have to set the e-brake to do this. These symptoms are different than the ones for a failing CPS. I know this because I just had symtoms for a CPS and had it replaced about 700 miles ago. Reset the idle a week ago after noticing these problems, with no change.
This morning it had a very rough time starting up. Almost as if it had been sitting in cold weather for a long time (hesitation during crank). Also today, a new symtom has shown up: bucking/hesitation while driving. Makes me have to plan my route around where the best place to break down is!
I'm not geting a CEL, but I pulled codes anyway:
KOEO: 539.....542 & 211
KOER: 538, 536, & 521.....then engine died before stored faults.
Usually if it does stall, it will start right back up again (not possible if CPS failure). But now with this new hard start and bucking under power, I'm worried that one of these times it won't start anymore.
I spent all last night reading threads on the subject and there seems to be more of you pointing to the IAC than anything else, but there has been mention of everything from the TPS, MAF, plugs and/or wires, to sludge in the throttle body, vacuum leak, EGR, and fuel pump, etc. Money is tight right now, so I was hoping the details above will point to something more specific.
Let me know if you need more info,
Thanks Guys, great site!
