Need SHO wisdom...Advice...HELP
Pete89sho
Belle Vernon PA USA
Just read the codes on the 89...need a little help here...what sre these?
IAS output voltage
PIP Sensor...TFI Module
HEGO...running lean...front and rear
ECT out of range
low speed fuel pump relay open
Fuel Pump Secondary Circuit failure
Does this mean my fuel pump is shot...and I need alot of work?
If it is just the fuel pump I may get to keep the car...if it is more she has to go
ryancutler
Somerset, WI
THat one just means that the car killed..
the only one i know, sorry..
ryan
Ryan
[email protected]
Yo Mamma Osama!!
[1992 Silver MTX]
IRT Performance Clutch, Dynomax Exhaust, Lund Tail light Covers, Coneless, K&N
[In Closet]- NOS #5120, red neons, red wheel lights, blazer techs, side marker lamps
[Next]- Rebuilt 3.2 with Ported & Polished Heads, Raised Compression, Stage II Cams, Adjustable Cam Sprockets, Stage IV IPT Clutch, 3 Angle Valves, Upgraded Valve Springs, IPT Coil Overs, Guages (A/F, Oil Pressure, Temp), IPT LSD, 17x7 Konig Caffeines, Nitto 450's 225-50-17, and PP y-pipe
[1993 Green ATX] -4 SALE-
Coneless, 73mm MAF, K&N, Superchip, DynoMax Pipes w/ [Glasspacks (Click 2 See Video)] -- [Another Video], 68mm TB, Removed A/C Compressor, Filled Body Molding (Gold), White Faced Guages, ACCEL Super Stock Wires, Powdercoated & Polished Intake
89 Gary
Millbury, Ma.
I'm not up on the code bit except I know the "PIP" is picture in picture which I have on my sony T.V.
Anyways,you could have just one bad sensor which could be giving most if not all those codes.
SLOSHO89
San Luis Obispo, CA
Well, I'll tell you what I know.
That has to do with your oxygen sensors. (you might need new ones)
Don't worry about that too much (it will come up when ever your car dies/stalls) and doesn't mean much.
Good Luck
Oxford White '89 SHO
Slicers, SHO+ hood and spoiler, Met.-Red and Gold Intake.
Web Page www.geocities.com/web_page66/
