Need instructions
Mike Stitzer
PA
I need someone to email or post some instructions on how to change the struts and springs on a 95 MTX. I've thought about it and I'd like to do it at home if possible. I know I'll need a spring compressor and that's no problem. Do I need a lift or can this be done on jackstands? Any info would be greatly appreciated.
Mike
That's quite a few instructions. You may want to get the Chilton's manual. Those instructions can be very helpful. You can do it with jacks and jacktands. Just work on one corner at a time. I have used a 1.5 to bottle jack between the lower spring perch and the brake caliper to easily slip the spindle off the strut. Try to mark or anchor the upper front strut adjustment plate to get the caster and camber back close to the original after the work on the front struts.
