need info on new HID project (pre-info)
Blanik_SHO
Montreal,Canada
Hi everyone
first of all I just want some advice.
if eveything seem possible, this summer i'll begin this project.
First off all, i'v seen this over Ebay and my friend got a nissan Sentra SER and install those style of light and it work very well , he got a powerfull blue purple light.
http://cgi.ebay.ca/00-05-FORD-TAURU...6602409QQihZ013QQcategoryZ33710QQcmdZViewItem
So i think and look over my store and see that taurus 2000-05 got the exact same "bulb" (9004 or so) as the 95 SHO. So i sayd to my self it would fit!!!
but after seaching some peaople says that our gheadlight can't use this because of the "frost" finish on it (stupid lens). Because no other clear headlight was made for our car i maybe want to buil one.
So here is my 2 question.:
-even if we have frost lens, do the back of our headlight are like reflect chrome?
-Does anyone were able to separate the lens from the headlight assembly and succesfully put them together after without leaking or braking? (use silicone, clip, anything.
Here is my project. IF IT CAN BE POSSIBLE:
-buy the kit over ebay.
-Take out my lense from my assambly.
-try to make a copie of the lens with "clear polycarbonate lexan" (its like plexiglass but unbreakable by bending and you can heat it witthout damage.
so with a oven and some time i coulb possible to "bend th plexiglass and assemble it like a clear lens)
For sure i'll try to make the lense first before buying HID light.:oogle:
kzoosho
Holset HX52
grand rapids/kalamazoo
Do a search. There arent many of us with hids ( i have them) but i have well over 1100 into my lights and it is a lot of time also. To answer yur question a clear lense would help you to put in projector yes but just to put a hid bulb in it is going to give you a bad hot spot. If you are going to run hids please use a projector or it is a big waste of money and your lighting will be worse than b4.
