need help with cluch
Telicus
Redding
this is in replay to cluch problem thred. I need to know what cluch I should buy and if it comes wiht a flywheel if it dosent then were can I find a flywheel for and 89 sho. here is the web site http://www.shonutperformance.com/
<small>[ January 07, 2003, 05:47 PM: Message edited by: Telicus ]</small>
revhardSHO
Seattle, WA
You need the $219 Clutch kit. You can get your flywheel re-surfaced at most machine shops. About $35
You may also want to get a rear main seal
RStalveyARFF
too many shos
Georgetown, MA
You first need to verify whether you have a 9.25 or 9.75" flywheel. Pull the starter off and note the location of the pressure plate. If it is not flush with the end of the flywheel, it's a 9.25" and you'll have to purchase a flywheel from Josh as well. In 90 they realized the 9.25" clutch was not a good combo for the power output, so they did a TSB (recall too I think?) and replaced them with the 9.75" clutch.
