SHOracer14
Me-0 Diffs-6
OK... so about a week ago I noticed a sizeable fluid leak from the middle of the car somewhere. It was dirty and dark so I couldn't tell what it was. I checked the oil and level was fine and then I figured it could be power steering and left it alone for the time being. Today I decided to check what was leaking and from where. I got under the car and most of the wet area was around the rear of the motor saying to me possible rear main seal. I start looking at the wetness and decide that it has a slight redish color. I pull the tranny plug and feel inside and I HAVE NO TRANNY FLUID INSIDE!! I said to myself, "Holy **** did I blow a diff and not know it?" I'm pretty certain that the differential is still intact as I haven't had any driveablility issues and no weird noises of any kind. Well I just decided to go ahead and throw some fluid in and see what happens. It takes all three quarts and so I get under the car to put the plug back in to find fresh fluid dripping out from the back side of the bellhousing. As I investigated as to where it may be coming from I notice that it's not coming from a seal and running down it looks to just be seeping out the side of the tranny case. I wipe off whats there and imediately fluid re-appears from the same spot. It's right on a line that is cast in the tranny right to the left hand side of where the passenger side halfshaft plugs into the tranny. I'm guess that there must be a hairline crack there or something and the fluid is just seeping out there. What should I use to fix this?? I really don't want to have to do ANOTHER tranny swap and the clutch that's in there seems fairly new (I just got the car so I don't know). I figured I might just try some JB Weld and patch up the area. What do you guys think? Has anyone ever heard of the case cracking without a differential failure?? It's definately not from a road hazard as high as it is unless a massive rock got launched in just the right spot. I have no clue what to do!
