Need help quick....please, cold weather problem
tauruswithheart
CT
Im posting this for my buddies 94 mtx......stock except for maf and lpm.
the car is misfiring only in freezing temps.
Ok this has been a reoccuring problem, when its freezing out.... but now it seems the coil pack loses its integrity when cold air rushes into the engine compartment.. because at idle sitting still while its warming up it runs fine.......and drives fine for like 2 min....the plugs and wires have 10k on them. and its has a pretty fresh 60k.
car has 142k on the clock. and i dont think the coil pack has been changed....
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
You really need to pull the EEC codes first. :)
Why do you suspect the coil pack? Ive rarely heard of coil packs failing.
Id suspect the MAF in regards to low temp misfires before suspecting the coil pack.
tauruswithheart
CT
there are no codes........no light ever......maf is 80mm with lpm and he replaced it with stock and took out the lpm and still the same thing.... no codes at all....weird right?
Racer X
SHO Pilot, Retired
Connecticut
I have the same problem with my car. Cold starts, and it'll misfire for a couple of minutes, and then smooth out eventually.
It's been doing this for 3 years, and I still don't have it nailed down.
SHObill
'The Collector'
Rochester MI-48307Detroit
Clean all ground path connections! Starter also! Add a ground wire to the 2 lower screws on the DIS to the strut tower or firewall, add a ground from the throtle body to the firewall. A good ground path solves a lot of issues!
tauruswithheart
CT
ok there are codes actually.... he didnt do the paperclip test right.......he has the general 114 code. and 511........
114 iat out of range......
511- bad pcm no power to pin 1..........????????????????????????????????????
tauruswithheart
CT
i told him to take the lpm out but he didnt so that explains the 511 code.......114 is cuz of the conefilter i think....
