SHOntell
Folks
I need help with my rear swaybar link replacement. I am replacing both sides with new reinforced links during my prep hour in the auto tech room in our school.
Problem, when car is lifted, I can't get the swaybar to swing forward enough to get the bolts screwed tight once I put the links in and connect to strut. So, I dropped the car down with tire on and this makes it much more difficult tighten. I did the best I could, and test drove.
I noticed some clunking that must be the fact that they ar not tight enough.
So, what is the procedure for changing??
Please and Thank you!!
Thanks, Mike
Thanks, Mike
