need help for 2 problem!!
Blanik_SHO
Montreal,Canada
Like i post a couple of week ago, i recently buy a new SHO 95 atx.
the prob is a got to change the two o2 sensor, so does anyone know a place for o2 not to expensive but in same time not a cheap jobber sensor.
But the major problem is that a got a transmission leak on my car. Recently i put the car on 1/4 miles (by the way i only do 15,9 ..... :( And imediatly after that i saw some oil comming on the bottom of the car. I bring the car to ford and they says there is a leak of atx fluid between the engine and the tranny (But i loose a lot of oil only like i rev a couple of time at 6800 rpm, when i use it slowly (like max4000) i didn't loose to much of oil)
Is there anyone who had the same problem or know which gasket could be broken....thank
Moneypit
Houston Texas
if its oil between the motor and tranny its the rear main seal. I beleive the only places on the tranny to leak are the driveshaft seals and the speedo cable...
Blanik_SHO
Montreal,Canada
so it is probably more the rear main seal then the speedo cable!........Is it expensive and is it difficult to change? I have some good basic and tool in mechanic. Did you ever do it or someone got hint on how to drop a automatic transmission and change that seal?, I nerver do a atx tranny....(always got manual car before)
fastsho92
SHO POWER!!!
Exton P.A.
here is a place for your O2 sensors. http://www.midwestsho.com/catalog/index.php
This is where i got mine at. they are $50 a peice, i think. you really can't get any better then that and they are about the same price anywhere you look. www.shoshop.com has them to. but they are a lil more money. midwest sho takes a little longer because they are not a big comany but they got here and they worked very good. so that is the place i would go to and i did! lol sorry i can't help you with the leak i got a MTX so i don't no anything about ATX's sorry but i hope the sites help u for your O2 sensor problem. :D
