need help fast (pics)
presidentpoo
Texas
i am in need of pictures of the whole power sterring ststem. from the resevoir to the pump to where the lines run and the routing of the cooler and what not. once i get the ps installed she will be hittin the streats!!!!
Phoenix
SHOHOLIC
QC , Canada
heres one
presidentpoo
Texas
thank you that will help some. any more would be greatly appreciated. turning into hulk hogan trying to turn the wheel
Phoenix
SHOHOLIC
QC , Canada
This is all I got , the first pic is only to show the lines to the PS cooler.
presidentpoo
Texas
okay i thought the cooler was the swuare one notthe straight piped one. where on thefront does that mount? the rounting is pump to cooler, cooler to steering rack, steering rack to pump?
presidentpoo
Texas
okay so this goes from pump to rack
this is the hose theat goes to the cooler i believe also comes off the pump?
this is the res obviously. now i have a fat tube also. i know it goes to the res but where does the other side go and also what hooks up to the skinny port on the res?
one more thing could i get a pic of res and cooler install locations
pjtoledo
'ol man in the SHO
toledo,ohio,usa
the big hole on the reservoir is the gravity feed to the pump, the small is what fills the res, not sure exactly where it comes from
by the way, steering the car without power assist is gonna screw up the slider sleeve at the lower end of the steering column. it is in no way built to take that kind of torque, you'll wind up with lots of play in the wheel because the slider looses up from the torque.
presidentpoo
Texas
okay so the large port on the resevor goes to the top of the pump feeding the fluid. then the shorter threaded line goes to the rack. then the line hooked to the cooler in the picture goes rack to cooler and a smaller (probably 3/8) hose goes from cooler to resevoir. all lines following a path behind the engine and to the cooler on the drivers side fender wall?
crystizel
