Need help.. Cd player blown fuses???
SHO-TYYM
SHO Rookie
Belleville/Madison, WI
Hey i recently decided to get a new cd player for my 94 SHO. I picked up the for 94 and up premium sound wiring harness and a buddy and i installed it ourselves. It worked for about 4 minutes then completely stopped. Turns out one of the yellow 20 fuses blew so i replaced it. Then attempted again. Everything lit up but no sound will come from the speakers. Another friend tried to hook up his cd player in my car (dumb idea) and that didnt work at all, turns out that it blew another fuse and i didnt realize that until i got to Madison (20 miles away) and tried to get back into my locked car through the keypad and the fuse that blew controled that... Spent 30 minutes fabricating a coat hanger lol. Anyways Im wondering what the problem could be? Down by my fuse box there is a single red wire exposed that isnt hooked into anything and i think that it use to be but i have no idea what? ANy ideas fellas. Thanks a lot and if you need to know anything else just let me know. Jonathan
SHO-TYYM
SHO Rookie
To the touch? No. The power works and everything there is just no sound coming from the speakers. Is there something that has to be done with the two stock amps in the SHO with the jbl premium sound? There is a red wire hangin around down by the fuse box and im not sure if its suppose to be wired into the fuse box or just hang there not connected to anything.? Any response? Thanks a lot ...... JOnathan
Endri_SHO
SE 300 , S 500
IN THE MERCEDES-WORLD
hey man,
unplug every connection you made, redo it from teh begining again, and make sure at this time you have your ignition key off before you install the stero again. lmk how turns out.,.,
good luck
endri
