Trying to drop the sub frame to get the damned alt. out because it went dead on me. Question is can I lower just the rear or do I need to lower the front and the rear? Also, do I need to put jacks under it or anything?
The stock V8 SHO alternator will have either a 56 or 57mm pulley depending on which year. The Windstar pulley will be 64mm. Get a caliper and measure the tops of the rib grooves. It not outside the realm of possibility that you've been driving around with the wrong pulley on the old alternator. The OE pulley is black, not zinc plated.97V8SHO said:I got the new alt today, it has a zinc pully but it's the same size as the old one from what I can tell by matching them up. Will it cause a problem still or no?
