Nick's SHO
Need an ecm computer for 94 atx asap
i need to borrow an ecm computer for my 94 atx to try an fix a problem ive had for about 2 months.if i find out that the problem was that, then i will return it to you and buy another one either new or from a junkyard. If someone has one let me know asap. Thanks
Read this an tell me if that sounds like a computer problem
http://www.shoforum.com/showthread.php?t=52546
Ive spent a good 600 dollars tying to fix the problem but nothing has changed.
Replaced:
Fuel Pump
Fuel Filter
Spark Plug wires
Coil Pack
Fuel Pump Relay
DIS module
Cam Sensor
theres not much left to fix now, but the problem has not changed one bit
Replaced:
Fuel Pump
Fuel Filter
Spark Plug wires
Coil Pack
Fuel Pump Relay
DIS module
Cam Sensor
