nik97 said:
Huh, that's seems like a hassle. Perhaps with only 5psi, a fuel enrichment setup combined with Doug's(FPS) forced induction flash will provide the proped mixture. I already have the Xcal1 with a 93oct flash and Doug has the program. I suppose I'll try to give FPS a call and see how they run thier '96 with 30#ers. I realize that going much over 90% duty cycle on the injectors will fry transistor drivers and even short them causing a cylinder to fill with fuel and make custom conn rods. -Thanks for the info!
I spoke to Carter on this and it seems that a 5 to 6psi boost level will work with the stock fuel system along with some type of FMU.
I've been looking into this for a while and here is what I have for a parts list:
*Garrett GT37 (GT3782) Journal Bearing turbo
*Vortech FMU (10:1 ratio)
*Turbonetics Deltagate wastegate with 3# and 5# springs
*Turbonetics Raptor BOV
*AlkyControl progressive alcohol injection kit
*Misc Aeroquip fittings and braided stainless hose
*Innovative LC-1 stand alone wide-band kit
*Misc exhaust pipe and bends
*K&N air filter
*Misc electronic parts and wiring to relocate MAF and front fuse box
*Battery box and related parts to place bettery in trunk
*Heat insulating wrap and reflective adheasive insulation for affected areas
*Lots of fabrication time
*New mufflers and 3" exhaust
*3" electric exhaust dump for fun
*various gauges:boost,fuel press,EGT,oil press,trany temp
*large tranny cooler to help tranny life
*a little luck
I also have a set of Lumina Z34 hood vents I'm going to try to get to fit on a used hood I have to help with under hood temps.
I have set a budget of $3,500 for the entire project. Most of the items above I can get very cheep (dealer cost is nice) and all of the fabrication I'm going to tackel my self. Should be a fun project.
Here is a pic of my last turbo project. I build the down pipe, exhaust and custom A2A intercooler set up for my Typhoon.
