...replacing my heater hose. My 89 SHO has developed a coolant leak in the heater hose where the rubber hose has a metal crimp onto another metal hose. I searched the forum, and it seems the OEM parts to fix this are no longer available. So what i have been considering is either(A)cutting the rubber hose before the crimp and getting a 4 inch piece of heater hose with a couple clamps to replace the existing rubber hose, or(B) buy enough rubber hose to replace the entire peice so that there is no metal hose from the rear of the engine to the heater core. I would like to try option A, but I don't see any good way to get a pair of cutters or my dremel tool in the area to cut the crimp. I need some suggestions on the best way or place to cut that hose, or if you have a better idea for a fix let me know.
Thanks
Thanks
