Name This...Please!
Best Sho
Hudson Falls, NY
Is this the inner tie rod? If not what is it?
There play in the tie rod and in this piece. There a squeek when turning and it comming from this area.
www.photoisland.com password brianna, folder tierod
Thanks, Mike
Ferendon
Fort Worth, TX
Sway bar Endlinks are cheap, and make a big difference. Get a set of MOOGs, they're greasable I believe, and you can get them at any O'Reillys.
Best Sho
Hudson Falls, NY
Changing Swap Bar End Link? Big Deal?
Hi,
Is changing the Sway Bar End Link a big deal or is it as easy as unhooking the bolts / nuts then putting the new one on. Would I need a alignment?
Anything I should know before doing this?
As you can see in the pic at the start of this post the boots are pretty shot up.
Thanks, Mike
projectSHO89
SHOless In St L
sdpatt said:
I found very close replacements of the upgraded composite sway bar links at AutoZone. Here is my writeup in my lower control arm topic.
http://www.shoforum.com/showpost.php?p=270944&postcount=8
While Scott has had good luck with the AZ endlinks, I have not.
I went through two sets of them, each lasted around 12 months. They come with a paltry 3 month warranty at last check. That's $100 bucks blown...
I replaced them again this spring with the Moogs. Lifetime Warranty from O'Reilly's.
Steve
BlankDisk
New Mexico
NAPA recently started selling a new type of endlink. I replaced all 4 of mine and the handling improved greatly. It's a dark metal one, and comes with a screw-in drain plug for any excess water that gets into them. Well worth teh money
pjtoledo
'ol man in the SHO
toledo,ohio,usa
Huh ??? :confused:
Guess I bought that grease gun for 'nuttin.
Perry
pjtoledo
'ol man in the SHO
toledo,ohio,usa
NotSoSlowSHO said:
Simple replacement. No alignment needed.
I also recomend the MOOG greasible endlnks :thumb:
Agreed it should be a simple replacement,,,,,but,,, here in the great northern rust belt those nuts often need cut or drilled off.
Perry
DHMag
Free At Last
InCahoots, Texas
drain plug ? hmm, thats a new one. show me a pic.
TimboSHO
Intermediate
Wyoming, MI
Part Numbers?
Anybody have some part numbers for the different endlinks? I checked SDPatt's PN for the Autozone ones and it said 'no parts match.' I also have a Napa and Advanced Auto near me. Anyone know prices of those? I'm having trouble navigating through their site....
TimboSHO
Intermediate
Wyoming, MI
Does anyone know how good the Advanced Auto endlinks are? Part number 18136. Thanks.
revhardSHO
Seattle, WA
Autozone and Advance Auto have both recently upgraded from the plastic endlinks to solid metal units. I forget where I bought the MOOGs (they are non-greaseable), but Im thinking it was Advance Auto. Other endlink is still metal but the shaft is a bit thinner and overall it doesnt look/feel as strong as the MOOG links, but both should do the job quite well. Price has not changed @ 24.99 each.
pjtoledo,
I hear ya. The nuts/studs are hard as **** to remove up here. The easiest way Ive found is heat up the joint with a MAP gas torch, pop it off with a hammer (or crowbar, but be careful) so the ball/stud is exposed. Clean it up (so it doesnt smoke), reheat the nut until red and put a vice grip on the ball to stop it from turning. Use an impact to work the nut off. The 5/16" connection on the front of the stud is just too small (Ive broken 3 sockets) to handle the rust. Another improvement with the new endlinks is they have a 17mm (or 19mm, cant remember) groove behind the stud making installation and removal a breeze, even in the rustbelt states!
