n20 questions.
pyro719
colorado
Ok Im about to install my 75 shot zex kit, and need the right spark plugs, what should I get? And on the nmu it has a hose for intake and ont to the fpr where do I hook these up to And when should I hit the button? 3000rpm in second gear? Thanks nitrous guys!
masho95
got Zex?
Chicopee, MA
Autolite 3923.
The intake hose from the NMU goes to the spot where the FPR hose is connected to on the intake. The fuel hose from the NMU goes to the top of the FPR, and you just eliminate the old hose from the FPR.
The NMU needs to be setup before use, and once set it activates the nitrous when the car goes WOT. There is no button, unless you plan to wire one in somehow.
BTW all this information is probably out there on the forum already. The Search button is a great tool when looking for information.
Good Luck.
Geek SHO
SHO Addict
Rohnert Park, CA
pyro719 said:
So I should spray it at what rpm?
You can spray whenever you want. You can just leave the system armed, then mash the throttle when you want the N2O. You might not want to go much lower than 2500 rpm to make sure you have plenty of oil pressure in your rod bearings before you start slamming the crank. I don't have an oil pressure gauge on my car, but someone who does might give you a closer estimate.
jayparot
NOS SHO
connecticut
i just got my NOS wet system need help
i bought a wet kit 100hp , single nossle injector , does any one think this kit might prone to do pooling on my intake my car has 116000 milles i have Y pipe
nology wires accel coil dyno it 189 hp 180tq is that good i'm new on this so i need alot of help plz .
Thanks
Jay
BlackonBlack89
burlington county,NJ
Thanks
Jay
Yes it will pool and then you have a SHOboom. you will need to drill hole in the runners to run the wet kit.(I have no clue where/how/why; I just remeber this from the many threads about this topic) I think doug(SHO dude) from FPS has his old intake for sale. it been for sale for a while now, i think.
jayparot
NOS SHO
connecticut
Really dammmm pay good money for this kit ......, i guess i'll have to send it back ... i just dont like dry kits . what do you think about the power my car has ?? it's a 95 mtx 3.0 where can i buy a good dry kit ?
does any one know who works on this cars in connecticut ?
plz i'll take any GOOD advise .
BlackonBlack89
i see you are new
use the search button, it will answer almost every question about N2O. is has been talked about so much. i forget the part number but it is on this forum somewhere plus everything about n2o
Geek SHO
SHO Addict
Rohnert Park, CA
In my experience that seems kind of low. Are you sure it has a high flow Y-Pipe? Because my '89 made almost identical numbers, but with a stock Y-Pipe. With a Y-Pipe it made an additional 9 hp and tq.
Get the 82011 Zex kit and Autolite plugs. You won't regret it.
jayparot
NOS SHO
connecticut
well i bought my Y pipe fron shobros garage , and my 2 1/2'' full exaust from dynomax , my car is a 95 MTX , about the NOS i call the company and they are sending me 5 more nossles and the parts to make it wet direct port . now about the plugs what number they should be ? i'll be running 100hp NOS .
also in the near future i want to add the BBB's and the port runners and tanks . now i hope shobros sold me high flow y pape if not @#$%$%##$
you get my meaning .
jayparot
NOS SHO
connecticut
help with my SHO 95 MTX
hey guys what other MODs can be done on the SHO ? and where can i get them ?
jayparot
NOS SHO
connecticut
well it cost me only 469.95 new , and to return it and get a dry kit ....... you know it will take a while b4 i can drive FAST lol , but hey if you know where i can get MOds plz let me know !!!
95 MTX green
shobros Y Pipe
Dynomax full exaust
nology wires
accel coil
eibach springs
AND NOW 100HP wet shot NOS
jayparot
NOS SHO
connecticut
here are my result with a wet direct port kit 100hp , there are 3 runs 1st with car stock 2nd with all the mods i did to it and 3er with NOS wow huh?
