i dont have a trunk key and the lever inside wont pull up like it seized up and i never locked it. advice?
Remove the little cover and use a screwdriver to unlock it by inserting it into the side and wiggleing. Might take you 5 minutes...tops.
that sounds alot easier. im going to take a look at it when i get home. any way to get a key or do away with the locking mechinism?
The screwdriver will become your key. It's so easy, even a caveman can do it.
i do but i do not know the keyless code.
Beleive it or not, not all 1/2 gen SHOs have keyless...
http://j-walkblog.com/index.php?/weblog/comments/keyless_entry_hack/
Then, when you get the trunk open write down the code on the white sticker on your keyless entry box.
holy crap is that real?
