javve
SHO Lovin' It
I swapped the EATC and Radio locations when doing the blend door actuator. I have a little bit of cleanup to do to make it look sleek around the bracket for the radio and get the EATC to sit in place a little better.
New wiring ran under the carpet as well as to the speakers. Passenger side I went through the rubber tube on the door.
Power distribution blocks mounted in place on the old factory amp bracket. Wiring nicely cleaned up with velcro tape.
The look of the finished setup. I used plywood mounted to the other old amp bracket, then mounted the amps to that. On the left side behind the carpet is where I relocated the wireless key module too. No need for the old black board at the back of the trunk and people are unable to see my unlock code.
The box is a 12" bandpass. It has the sealed side on the back side of the speaker instead of on the front.
Two Rockford Fosgate 6 x 8's in the rear, Two Clarion 6.5 in the front doors. I will replace the door ones later for components. I found the clarions at the JY for under 10 bucks.
Rockford Fosgate Prime 300.4 for the speakers
Rockford Fosgate Prime 500.1 for the sub
