my sho hasnt ran in 16 months...
Fordtaurussho
Manitoba
there is a main harness wiring x connector, i dont know where it plugs into, and i have four wires that are supposed to go to the starter solenoid but im not sure
Fordtaurussho
Manitoba
on the main wiring harness there are 2 black male plugs, 2 gray male plugs, 1 gray female, 1 black female and there is an x connector 2 black females and 2 gray females where does the "x connector" go between
they are the biggest round connectors on the main harness
also i have four wires coming out of the main body wiring that are supposed to go to fusible links i believe, small yellow with gray tracer, small yellow with white tracer, big beige with red tracer and ********* with yellow tracer
car does not crank with the key, when i jump the starter solenoid car cranks but with no fuel pump, no spark
KyngofPop
Freday-day
Charlotte NC
....edited...smdh.
Are the wires cut, burned, frayed? What exactly is an "x" connector? Do you have or can you post pics?
crystizel
