my sho has some balls now
Revere sho
Revere MA.
i wanted to say thanx for all of your advice on my sho.
my car runs the balls now. im still going to do some more maintence on it but all those engine problems i was having before
bogging, running rich, no power, mis firing, thinking i had clogged cats, black smoke coming out the back and probably a couple of other things i was experiencing are all now gone.
well i found out everything when i was looking in the back of the motor to see if i could do a tune up with out taking the intake off. when i looked back two of the ignition wires werent even touching the spark plugs. so i put them on. while looking at those i found a wire that was disconnected from something and it was hanging. i plugged that back in and now the car runs the balls. i dont have any bogging and i have alot of power now. i still have a little bit of black smoke coming out of the back but it looks like its just left over from all the crap i had before. that should be gone by the end of today.
thanx again for all of your help and im still going to get all that other stuff so my car can run even better.
Toolman
Boost it!
Grand Lake, Oklahoma, USA
It usually is the simplest of things. Go get dyno'd, and go beat that WS6! So, what does a 4-cylinder SC SHO run like?
Revere sho
Revere MA.
it ran like crap. i swear my moms neon would take me off the line to 60mph. it sucked bad. and it made all kinds of weird sounds. lol
Revere sho
Revere MA.
o ya mysho1 if you want to beat on an srt 4 and you are free tonight go down to south weymouth at the old air field at like 7 tonight and its free. its a dodge event if anyone ask just tell them melrose dodge sent you and if they ask you the sales man just say corey nance. its really really fun and its free and if something breaks on them then you dont have to worry about it lol and you can also ride with a pro and see the thing really move its ill
o ya you can drive an ion redline to there.
SHOkid13
Take it to the track
Temecula, CA
I'd run the codes and the cylinder drop test to make sure everything is going okay. Usually the only issue you will have would be possible cat damage. How many miles did you drive it without the wires connected?
Plugs should be fine, if they weren't sparking, they're probably cleaner than the other plugs! :)
