I just got done installing a reman fenco rack for a slo. When I was cycling the wheel to purge the system the rack cracked. The case got a 5" long crack on the passenger side. I think this happened when I hit one of the stops. I hope this isn't from installing the slo rack without spacers. I didn't slam the stop, I was gentle.
One of my spacers was junk that's why I didn't transfer them over. I had the lines hooked up correctly and that valve installed in the high pressure line.
Ohh and I did my clutch also, and my new luk tob is making a high pitched noise until you push the clutch in or lift on the pedal. It was coming and going though sometimes.
I've just about had it, next i'll find out I didn't put the trans back together right, then i'd lose it. It seemed to shift good though. I was all excited for the new clutch and welded diff, now this.
Any help or ideas would be much appreciated, hopefully it was the rebuilders fault, but I think it's another issue.
