my hazard lights dont work AT ALL
SHOguy 92
Duluth, MN
first off what were u just doing the morning test of all the lights on the car to figure this out? i really don't know what ur problem could be maybe a wire disconnected somewhere but thats just a guess.
V6&V8SHO
wauconda, IL
My car does the same. I belive it is caused by a failing muti function switch?? dont quote me on that
91 SHOplus
Sholess 4 Now
North Jersey
More than likely, there's sludge built-up under the hazard button on the top of the steering column, not the MF stalk.
Do a search, as the procedure was listed only a week or two ago. I beleive the cure was as simple as spraying degreaser on/around the button and repeatedly pressing the button in/out, untill it worked it's way in.
SHOguy 92
Duluth, MN
might bethe combination switch? take a look under ur steering column on the side thats closer to the stereo. lots of switches go there:wind shield wipers and some other things that'd be my guess
rlw001
Reading, PA, USA
It is most likely your multi-funtion switch. They cannot be repaired and must be replaced. I bought mine from FPN when my turn signals stopped working, I think it was less than $50.
<small>[ October 04, 2003, 11:28 PM: Message edited by: rlw001 ]</small>
Ptatohed
S.D. CA
TheKrazyRaven:
wow everyone here is so cool and nice
anywhere else i would of gotten flamed for askin a question that had been asked
this place rocks :D
Well? Did you fix it?
tinkerkathleen
