My fight against rattles.
jmpSHO2nd
Massachusetts
Ever since I bought my SHO the rattles have bothered me. Anytime I remove a door panel I always use new clips and I dynamatted the floor, trunk, and two front door panels and to be honest it wasn't worth the effort, I never noticed much difference with road noise after the dynamat. I needed a new driver rear door panel and a new passenger front door panel so I figured I would try sticking some clear two side tape to the back edges. I was pretty successful at making sure it can not be seen once installed. Sorry for the crappy pics, they were from my phone. I only did the driver rear so far and it felt like it fit better but I won't know if it reduces rattles until I do all four doors.
http://doxinh.com/danh-muc/my-pham/nuoc-hoa/ Quan ao lot nhap khau Do lot nhat ban Do lot korea Dung cu tap an cho be cao cap Cho thue trang phuc hoa trang dep Do boi nu goi cam
94SHO_Norfolk
Norfolk, VA
I figure my '94 is 16 years old, so things are gonna rattle. I'll do an experiment and remove everything from the storage bins on the doors, and the glovebox, and see how much it still rattles. I doubt it'll ever be rattle-free, but removing anything loose from those door bins and glovebox should help. Plus, that's what the volume switch on the stereo is for...!
K-Dawg
Treasure Coast, FL
I've found that a major source of rattles and squeaks from the door panels is the different panel parts rubbing against each other, especially when I crank up the stereo.
jelloslug
Digital
Greenville, SC
The best thing I have found is to line any hole that gets a fastener with felt. That makes them fit tighter and will stop the panels and parts from squeaking. That took my super squeaky 2nd gen center console to rock solid and super quiet.
pitaSHO
Why do I do this to myself?
Lewisville, TX
My 91 has solid motor mounts, aluminum sub-frame bushings, and coil-overs and it doesn't rattle. :p
Chris K.
SHOCH
Tommy Boy
near SHOcago
I filled all my doors with expansion foam.
Honestly my track car with 165k is quiet and the wagon with 87k is so bad every door squeeks and even with the radio at 11 it's nasty. I'll wait till Spring to attack it.
lingyuair
