My datalog
SeanMc
NoMoSHO
Here is my TwEECer data log from last night. Not to many changes, since my motor is n/a, but let me know what you think. The car is an ATX.
Engine mods are:
3.3L w/10.5:1 compression
Ported and polished heads
Ported and polished intake runners (switching to recently purchased EH runners soon)
Radiused openings where the plenum meets the intake runners
Big bore butterflies
SHOShop stage 2 cams
Walbro 155 fuel pump
SHOShop in fender CAI
80mm Lincoln MAF
SHOShop ATX catted y-pipe, SHOShop catback, Magnaflow mufflers
Any advice on anything would be appreciated.
Thanks!
EDIT!!!:
Ok.
go here: ftp://bondosho.no-ip.org
Login with the username and password of tweecer. Download the db file.
Marcel (Ishodu) said I should log the MAF in volts next time...probably won't happen until next weekend, but I'll update the thread and file.
SeanMc
NoMoSHO
I don't see the log.
Yeah, wrong file...oops. Fixing.
Apparently all my files supposedly are bigger than the allowed size, and I cannot attach any files (renamed a zip file to a doc file, but my 101kb is bigger than the alloted 976kb???????????????). PM me an email address and I'll send it to you that way.
92sho16
b00sted
Liverpool, NY
I would get another with MAFV and VBAT if it doesnt have the issues the mtx have with VBAT. You can also you use SCT livelink to graph the parameters and get an idea if your afr tracks with what it commanded, that is if you have a wideband.
SeanMc
NoMoSHO
Can't get there .. says "page can't be displayed".
Hey Ransom,
Copy it to Windows Explorer, and it should ask for a user/pass. Copy the file over to your desktop and then open it up in CalEdit.
Rob,
No wideband right now :(.
Chris,
Go back into your hole :wave:
Sho Amo
SmkTyresntDrugs
Olney, Md
im not able to open it either? all i get is a blank cal con screen.
Edit: Never mind i just figured it out.
